H3 wheel spacers
Get_ARMED
US
Hey guys I just picked up an 06 H3 that came with 22 inch wheels on it. Now these are not my style at all, I'm a 15in maybe a 16 inch wheel with 33 to 35 inch tires on it kinda guy. Now I'm looking at wheels for sale on Facebook and offer up and see plenty with the same lug pattern but don't have the same Hub size. If I get wheel spacers will that eliminate the issue because the spacers are the the right size on the hub end and on the other end it doesn't matter?
Sent from my SM-G930P using Tapatalk
Lewiz VenomH3
US
Yeah. What about the offset?
Get_ARMED
US
I'm probably going to stay with the most minut spacer I don't need it to stick out too much further than where they're at but a little bit would not be a problem I just want to see if the spacers will eliminate my need to find Wheels with a 100.3 mm bore or if I can use the spacers and get a room that has a GM size of 78.1 millimeters
Lewiz VenomH3
US
1st is before. 2nd is after 2 inch spacers. Stock wheel. 3rd is current after frontemd lvl and 1inch daystar body lift.
Get_ARMED
US
That looks good man! What are you got now about 2 inches past the fender? See that's about as far as I want to go but I want to be able to buy any six lug Rim out there and if the spacers will let me do that that's all I want to know.
Lewiz VenomH3
US
Yeah 2 inch past fender. Buuuut these babies here is what i want with out the beadlock. Smaller tires of course. Got 35s now. Doubt my I5 can do 37s
Get_ARMED
US
Ideally I would do the same exact thing small Rim big tire now somebody wanted to trade me a set like that for my 22 inch chrome I would take it
Lewiz VenomH3
US
Trail worthy fab. Is a shop here in town. Check them out. They can pretty much put any logo on the rock rings
Get_ARMED
US
Maybe I should look into doing an LS Swap too so I can push those big old 40s.
What you need is an adapter. A spacer wont work because if you run a spacer thick enough for your lesser hub diameter wheels to clear the protruding lip from the stock H3 hub you would run out of stud length.
jay3817
Kentucky
Thanks. They are made for harleys and jeep. So had to modify the housing
I don't suppose you feel like doing a write up on it do you? I've seen those different styles of headlights for jeeps and was curious about doing a mod like that myself.
Lewiz VenomH3
US
If the weather cooperates this weekend I will take them apart. Il do a quick right up with pics and video.
Lewiz VenomH3
US
I've changed some things. New wheels and changed leds tint from green to smoke
