silvrzuki77
- Vegas
Hey guys, I have been busy with multiple projects but the latest is a set of bolt on sliders for my T. I have a good friend that has a company that builds badass stuff for toyotas. He has taken a interest in building stuff for the H3. Anyways he drew up some CAD design for brackets for 1 3/4 tubing. The brackets are 1/4 plate that are designed to fit together than weld.
Here are the brackets mounted on the truck. Perfect fit with the tubing. The driver side is notched to fit around the E brake system. (Havent worked on that side yet)
Here is the main tube with kicker.
Here is the outer tube mounted against the frame brackets
And the final picture is the brackets welded on. Still need some final bracing but gettin close.
