He He He
R
R-code17815
:wink:
:mock:
R
R-code17815
This is just a Universal Ford/Mopar style Rad
Bottom core support was made from 1/8 x 3" steel, 2 bends on each side
It mounts to where the factory side mounts are, 2 screws each side.
I used Prothane Big Block Chevy Isolator's on the bottom & a custom cut piece of 2" Alum Angle for the top hold-down.
Trans cooler is a B&M unit, 24,000 gvw. It's mounted solo in front of a/c condenser.
Stock clutch fan didn't clear lower rad hose on new on so....in the trash it went & slapped on an elect. one.
rallyrcr
Tacoma, WA
do you have any pics of the supports on the bottom? its too bad i just had a radiator go bad 3 months ago ($900) when I could have just done this instead. looks good!! post more pics!!! ...pls
