DaWgPoUnD
- South Carolina
2008 H3x I5 with 56k miles with a P0305 code on hand scanner.Intermittent P0305 code with an occasional dip in RPMs/miss fire on a warm start up.
PP TB, AirDo intake installed
All plugs changed, new coil pack on #1 and #5,TB is clean, MAFS is clean, clean air filter.
Swapped coil packs around trying to chase the issue...stayed on #5.
Took H3 to dealer...tech noted miss fires on cylinder 3, 4 and 5 (my hand scanner on picked up on #5). Tech moved coils around and checked plugs..all good and continued to get same miss fires.
Tech recommendation: remove cold air intake and PP TB and reinstall factory set up and see if problem continues.
Truck runs strong except for the occasional issue on a warm start up. I have tried top tier gas on several tanks with bottle cleaner (snake oil right...lol) and still have this code come and go.
Thoughts?
Thanks in advance.
Thoughts?
Thanks in advance.
