Head Unit install questions
Happy Hummer
Wisconsin
* Crutch field shows modifications to internal dashboard for double din install... Is this true?
I already have different antenna adapters I've purchased back some time ago...
* Does a metra 70-2003, gm-2004 and or gm05b scosche fit?
I don't really need the chime and I don't use OnStar lol! The rap feature is nice but .....:shifty:
* Is Kenwood Excelon a decent product? I've got a lower level single din in XJ and it works decent...
If there is a better h\u in your opinion pls do offer suggestions... I'd really like a nice quality h\u... Usb, bt, Wi-Fi,cd,etc...?
Chris
rja1766
Fairview Heights
Chris
I installed a Blaupunkt double din a couple years ago. I had the monsoon with the nav and satellite. It did not require any modifications.
The install kit is required for the amp if I recall. Mine sounds better than the factory, with factory amp and speakers. Louder, clearer. I paid about 180 on Crutchfield. Bought whatever they said I needed. It also allows to to turn the chimes down super low. .
brash47
US
Any pioneer avh4200 or above is a nice unit. They have AA and Apple Car Play. Install is easy. Just take your time and do plug and play harnesses.
Find the parts for install on crutchfield then get the parts on Amazon. It will save you a ton of money. I've installed 3 different head units in this truck and as with all gms, it's pretty easy
Refer here:
http://www.hummer4x4offroad.com/forum/showthread.php?p=217498
Happy Hummer
Wisconsin
So, I've noticed some have to cut the mount in dash but some folks do not.... I'd like to upgrade but not cut the dash parts.
Traxx
PNW
I've never had to cut anything, just used the Metra kit and slides right in.
Kick'n Dust
Dearborn Heights
I got my dash installation kit for my double din from crutchfield but can't remember if I had to cut anything. I'm running a Clarion Navi unit with a 4 channel amp. Factory amp melted down after the Clarion was pushing all that power to it. Anyone interested in the oem sub/amp package out of my truck? It's been just sitting in my house for about four years
Sent from my Coolpad 3622A using Tapatalk
humvee
Doha, Qatar
I got a metra + double din Sony off crutchfield, good interface and retained chimes and all.
The Sony unit itself needs a quick trim that I haven't gotten around to do, should be easy with a file or a small electric saw. It doesn't allow the dash cover to fit flush (pictured here).
No trimming need to be done to the brackets if you follow the selection steps on their website, and select a product that doesn't require modding. They know what fits and what doesn't, I was quite impressed.
This particular Sony unit was very cheap, no Bluetooth or gps, which is exactly what I needed, but it also comes with a non customizable blue wallpaper, which sucks.
humvee
Doha, Qatar
yes it supports videos and has a backup camera input.
But it doesn’t support custom wallpaper, so I was never able to use this skin.
I suggest get a model that does.
Japanese, Korean or American brands, stay away from Chinese head units, new ones look good but the audio internals are crap, and you’ll really notice the difference.
Good luck
awalsh
New Jersey
Didn't cut anything with a metra single din kit, also don't see what there could be to cut because the factory radio is huge and putting in an aftermarket is no bigger
