If you have leveled the front end of your Hummer H3 by adjusting the torsion bars, you may well notice that you suffer from front end dive when braking and excessive suspension movement. The Trail Duty Extended Bump Stops will cure this problem. Available in two sizes, +1/2" and +1", these poly bump stops will help prevent nose dive and reduce excessive suspension movement.
Important: The best way to assess which bump stop size is suitable for your vehicle is to measure the distance between the existing bump stop and the lower a-arm, (after adjusting the torsion bars). Ideally you want the new bump stops to have small gap, 1/8" - 1/4". It is important the new bump stops are not resting on the a-arm or supporting the vehicle weight.
The +1/2" bump stops are recommended for most applications. +1" are not recommended for off-road use.
