Home made cold air intake for the Alpha!
jmoffatt
Swamprat
Shreveport, La.
I made my own CAI for my Alpha for under $70.00, most parts were obtained from here,
http://www.siliconeintakes.com/index.php?osCsid=e347b2ab7041cf
parts were as follows
1' x3.5" aluminum pipe
http://www.siliconeintakes.com/product_info.php?cPath=19&products_id=279&osCsid=e347b2ab7041cf
4" to 3.5" silicone reducer
http://www.siliconeintakes.com/product_info.php?cPath=2&products_id=539&osCsid=e347b2ab7041cf
4"to 3.5" silicone 90 deg reducer
http://www.siliconeintakes.com/product_info.php?cPath=14&products_id=958&osCsid=e347b2ab7041cf
2ea 3.0" t bolt clamps
2ea 4.0" tbolt clamps
http://www.siliconeintakes.com/product_info.php?cPath=1&products_id=310&osCsid=e347b2ab7041cf
and a vacumn adapter kit from autozone which includes the holesaw , grommets and adapters for the cranckcase breather line , and about 8" of 3/8 rubber hose.
I had to cut the aluminum pipe down by about 2" and the 90deg elbow is about 1.75" long on the 4" side I cut that down by .75" for fan clearance measure where you want the breather line drill install grommet and adapter.
The worst part is getting fan clearance I finally had to snip off a 1/4" of the fan tips at a 45deg angle now I have about 3/8" clearance between the fan and the intake.
Kinson33
TX
Sorry to dig up this bad boy, but is anyone who did this still around? I ordered the parts listed and the 90deg silicon elbow wasn’t even close to clearing the fan blades on my Alpha!
Sennin
South Africa
Post some pics. But i had to wiggle mine a little. Almost at the point where i wanted to cut the leg of the bend shorter when I got it to fit. Could be that you have a longer leg on the bend and need to trim it a bit
Sent from my SM-N950F using Tapatalk
jmoffatt
Swamprat
Shreveport, La.
It's my thread if you read it says and I quote " 90deg elbow is about 1.75" long on the 4" side I cut that down by .75" for fan clearance" I cut it down on the side that attaches to the throttle body to allow for fan clearance.
Kinson33
TX
I humbly admit my oversight and thank you for your response. Thanks for not roasting me, I may not have been as nice when people don’t read all the way...
Trim trim trim until it clears
The stock plastic elbow has an indent in it to increase fan clearance
Kinson33
TX
Not sure how this is possible, but again shame on me for my oversight and not measuring before ordering parts.
I had ASSumed it would be straight forward but it turns out my airbox outlet is 3.5", which is very strange considering we both have 2008 alpha's @jmoffatt !
Luckily 3.5" rubber/silicon couplers are very common at the parts stores
Im guessing from this you are using a 4" aluminum tubing instead of 3.5"?
Yes the intake outlet is 3.5" while the tb inlet is 4"
Kinson33
TX
no, 3.5" tubing. OP listed he used a 4 to 3.5" reducer which i dont understand if the tubing and the box are both 3.5"
I'll get photos when I am home this evening. I might be coming across as pretty ignorant but I promise this is not my first rodeo in toying with upgrades :gaah:
The more I talk, the greener I am coming across. I'll just post photos when I'm done:sigh:
The straight 4" to 3.5" reducer isnt needed if you already have the 90* bend 4" to 3.5" reducer. All you need are 3.5" couplers after that.
I have the same setup and checked everything but for some reason I keep getting a MAF related code (usually for air leaks) and I checked the thing several times but nothing.
Anyway, good luck with everything and let us know how it turns out!
Some might recall my project in 2010 for comparison.
I ended up with 1/2 inch clearance at the fan using a 3 inch pipe. More clearance for offroad and looked safer to have that margin of error.
Looks like I did not get the boot on the box shoved on all the way for this image. Still some images on old hardrives somewhere. I had to dig up this image as Photopucket will not let me copy and past anymore. I have been running these for many miles, about 80,000.
