It then started coming on everyday, at which time I checked tire pressure, and found I had one tire at 30 PSI and the other 4 were still 50 PSI. I filled the tire and after 1 weeks time it would leak down from 50PSI - 30PSI. I brought it to a tire store and they said the TPMS sensor was leaking and needed to be replaced at 85$ for an aftermarket sensor and 50$ labor to replace and program it. ( needless to say I didn't do it )
Thats ridiculous. Quick background before I tell you my experiences on TPMS. I work for Costco while going to school. I was doing typical stuff there but the second they had an opening for tire center I jumped on it. Figured I might as well make work a bit more enjoyable then dealing with a bunch of grumpy people who treat you like ****. Anyways back to the TPMS.
Replacing an entire sensor for a leaking TPMS sensor is ridiculous. Dill products (thats what we sell) and I am sure many other companies sell a "rebuild kit" for the TMPS which basically replaces everything minus the sensor itself.
http://www.amazon.com/Dill-2030K-TPMS-Component-Replacement/dp/B001C6HEGY
Usually there is a rubber gasket on the TMPS sensor then put that through the valve stem hole then a washer and nut go on top. Torque it to spec and your done. The Rubber gasket is what causes the leak. A ton of tire shops and ESPECIALLY dealers will say you NEED a new sensor. Its BS. We sell the TPMS sensor rebuild kits for $2.99 a tire. $15 for an install. Normally we recommend changing out the rubber gasket if your car is a bit older while you put on new tires just for the fact that it only costs 2.99 and the tire is already open so you dont get hit with the added 15 dollar install fee. On top of that in the future I would look into sensors online, they are much cheaper then what shops will quote you. Costco sells the sensors for about 40-50 bucks plus the 15 dollar install so still much cheaper. That will be my route when mine die.
The H3 sensors are made well IMO. 10 years...Hell the hondas, toyotas and all that crap they are needing replacement before 5 years.
Now Costco Tire center on the other hand is hit or miss. The crew I work with are car savvy competent people (minus 1 or 2) for the most part but other stores may have complete morons I know I personally hate it because I feel like I do good work and can be trusted but I would watch them like a hawk the first time if you got sensors or something. Costco also used to be much cooler on installing aftermarket rims and bigger tire sizes back in the day but they had to many cases where someone would buy 28s for their corolla, they wouldnt fit and want there money back. They were sued too many times and now are only friendly to stock tires/rims, there are exceptions of course but its much stricter then back in the day. Too boot, their polices dont always make sense but again they over regulate themselves due to the issues of the past.
For me costco tire center would not be the first place I go for tires because I am far from stock but for a stock daily driver its a good place. They have road hazard included on all tire purchases, quality tires, etc. For sensors though stock or not, I would recommend them ...the prices cant be beat and they use quality stuff and I would hope they would not try to persuade you into new sensors like these other shops. I know we do not. We try to save the customer money....
