Hummer H3 PROP SHAFT
Oscar5
Colorado
I have a hummer h3 2008 and i recently started hearing like a loose metal clicking as my tires rotate. I took it to a mechanic and they said I would need a new front drive prop shaft. Anyone else every have a problem like this? The GM replacement is around 300$. I wanted to know if anyone knows a online website or store where I can find any.
Doubt that you need a new propshaft. You need either the CV joint on the rear end or the u-joint on the front end. Each can be replaced without replacing the propshaft in its entirety.
