I need instructions to Remove the SUN-FADED H3 Plastic-Trim Pieces=So can paint them
ludevick
Northern California
As far as I remember you’ll just need a philips head screwdriver and a t30. There’s a bolt or two at the top and then a couple song the sides.
Also I would inspect all the bolts/ screws on the roof. Loose ones can cause a pretty serious water leak inside. Trust me on that.
mjferencak
Elbert, CO
If your anchor nuts spin on you, you’re going to need needle nose vise grips to keep your anchors from spinning. I had two that came loose and spun as I tried taking the windshield molding off.
