The_Mountain
- Cow Hampshire
Just had to re-do the lower balljoints, and also do the uppers, and the front wheel hubs. Had that done about a month ago. Ever since, I've been fighting the alignment. The caster is way off (wants to pull further into turns). Finally went to a new shop to have the tires balanced, and they had a freebie deal on alignment. The old shop had told me that caster wasn't adjustable on the H2. I know that's not true, but didn't want to press the issue. New shop acknowledged that it is adjustable, but the upper control arm bushings are shot, so the right side can't be properly adjusted. So now I need to do the right upper control arm too. Grnrgngnngnggnnrrrn.
And on top of that the tailshaft bind is gradually getting worse, and the transmission is still weird. I need to take the truck into a good shop up here (just moved) to get that looked at; maybe the mechanics here in NH will be better at finding the problem. There's a lot of slack in the trans at very low speed, it still flips in and out of torque converter lock, and it still occasionally slips or doesn't fully go into gear under acceleration.
And the KYB shocks are also weird. They seem to work for high-speed damping, very stiff over rough pavement/potholes/etc. However, over larger irregularities, like dropping off low ledges (mismatched bridge section height for example), the truck wallows like a 70s Cadillac. I've had two separate places check the shocks, and they tell me there's nothing wrong with them, it's just the characteristic of the shock.
I'm worried that this truck is becoming a money pit. I don't mind spending for regular maintenance and the occasional larger repair, but this is a lot of expensive things going wrong in a fairly short timespace.
