ReconH3
Guardian Angel
- Raleigh, NC
They provide enough info to show some serious concern on two issues.
1. Bump Steer!!!. The reason for the bump steer is the track bar. It's nearly half the size of the tie rod. To avoid bump steer, the track bar and tie rod need to be as close to the same length as possible, and parallel. The one on this H3 definitely doesn't meet this. Hence the bump steer. The bent tie rod does nothing to help out. These are all fixable things, that in good hands, could be worked out.
2. The hack job for the steering box! There was no need to do what they did. If you have just the slightest front collision, the frame is going to buckle right there. The hack job pitman arm is also a bad sign. Will need some serious patch work to make it secure again.
It has potential, but would need to be worked on before risking any type of use.
