LED rear bulb help
mjferencak
Elbert, CO
I installed the LED bulbs in the rear and now have a fast blinking turn signal. Anyone install a LED flasher module or anything to fix the rapid blinking?
The bcm is detecting less current draw and is thinking you have a bad light, that why its blinking quickly. Some ppls fix is basically adding a resistor inline with the bulb to get current draw back to range.
Get a 6 ohm, 50 watt resister and wire it into the Yellow and black WIRES (left bulb) and D. green and black WIRES (right bulb).
