Massive Sun Roof Leak
H
H3Ray
Nothing but problems lately with the H3, and I haven't even started modifying it with bigger tires, wheel, winch, etc.
This morning I opened the door to find 3 inches of rain.
I just had the dealer come pick it up.
Dealer advised the head board area is all soggy, floor boards, etc.
Is this a common occurrence?
Thanks
Yes, very common. After the dealer does whatever they do, i would undo the drains and gut them so that water and debris will flow easily through the holes. The front ones are relatively easy to reach, rears take a little more effort.
Burn
Eure, NC
Mine was horrible, drain tubes and windshield leaks. Even after windshield replacement it leaked. I don't like sun roofs so I used sealant and went around the rubber gasket on the roof, now it is a moon roof. I painted the headliner to remove stains from the water.
H
H3Ray
BIG Thanks Guys! Well, the Dealer has the H3 so just waiting for a call back.
USMC_TOP
Muir Michigan
Mine did the same thing and Best is right it's a DIY fir sure. Dealer will probably want at least 4 bills and not correct the problem for long term
deserth3
Conroe, TX
The sun roof was never made to be water tight. It's designed to let water drain into a tub that runs around the edge of the glass. From there the is a drain in each corner to remove the water. Periodically it's a good idea to check these drains.
Sent from my SAMSUNG-SM-G900A using Tapatalk
