- Way up north, UT
So I started having starting issues again. Last time I thought it was either the starter or the battery. The battery definitely needed to be replaced, and after my trip to Moab it's actually charged up all the way now (I really should have put it on a charger before, but oh well). To recap, it's just not turning over at all, and it's not Passlock causing the problem.
I still don't really think it's the starter, but it is a possibility. If it is, it's the solenoid going out on it, but it's one of those things where either it works or it doesn't, it doesn't half work.
I'm starting to wonder if it's my park/neutral switch, since yesterday when it wouldn't start after several tries I put it into neutral and it started right up. The time after that, it wouldn't start and then I released the parking brake and it started right up (I feel like the parking brake pedal banging up might've shook something into position).
Has anyone else run into this issue before? I've got about 97K miles on the truck, so it seems like it *shouldn't* be having this issue, but who knows. I still don't think it's a problem with the starter, though that is of course still a possibility. I can't take it to a shop since it's so intermittent and completely random, though it only seems to happen when it's over 60 degrees out, but even then it's not a common issue during those conditions.
