My 08 H3 Alpha is running very hot.
08h3Alpha
Phoenix, AZ
Hey guys just wondering if anyone has knowledge of a good shop in Phoenix that I could take my H3 to. Is overheating I can't sit at a red light without it getting to almost red. Once I get moving it helps a bit. Need to get al fluids changed also, hope to get it to a good shop soon. Thanks
Reloader
Montana a free state
Where you located in the valley of heat?
I could take a look at it. Possibly bad fan clutch as you say it starts to cool down when you start moving. My alpha runs at about the 3/4 mark in traffic in this heat. Have you ever cleaned out the area between the radiator and condenser . I do mine once a year at least and get lots of crud out each time. I also have a body lift and my fan shroud isn't the most efficient . I did replace my fan clutch after moving here and saw improvement . Can also help you with the fluid changes. Trans , transfer case, both differentials ,etc...
Steve, let me know if I can help. I can always drive up to your place and help hand you tools and go get us lunch. I've learned a lot from watching what you do and how you do what you do.
I can attest that Reloader has successfully swapped out fan clutches, among other things. And Bigunit is excellent at grabbing lunch.
...and Alrock is great at driving me around Glendale to grab lunch! [emoji12] We make a great team!
Best4x4
Vidor, TX
My Alpha used to run pretty hot when I first bought it. I installed a Ford Metal Fan Blade out of a 96-98 Ford Explorer with the 5.0L V8, and I replaced the fan clutch with a new unit, swapped out the dexcool for a 50/50 mix of green coolant, and I installed a puller fan in front of the HVAC Condenser (uses PCM efan control). Now my temp gauge is dead center driving down the road at 75-80MPH, and at idle or in heavy traffic it sits maybe 3mm above half on the gauge.
Reloader
Thanks guys. I live border of Laveen and Phoenix. By 51st AV and Broadway.
You are not too far from my location . I am a mile directly east of Luke Airbase. If you are interested I have an opening Sat morning early to check out your over heating issues. When I say early I mean 6:00 am as it gets too cold later on around here. We can get your rig up on the hoist and take a good look at things.
What year is your Alpha, what color, adventure package?
Sorry guys, but I'll be in Alaska on Saturday and won't be able to get lunch. See you when I get nack
