Need an H3 front differental cover
Schwarttzy
Rockford IL
Nobody seems to be getting any real traction with fixing the (supposedly) weak AAM 7.25 independent axle. I do know of one thing that will make a difference, it's quick, and easy. Put a Heavy duty differential cover on the axle to help strengthen the housing and hopefully reduce deflection inside the housing.
I'm not sure if the 7.25 AAM matches some other axle out there that has HD diff covers already, but so far I'm coming up empty handed. Unless I find something soon, I'm just going to start making my own and know it will be a great addition to my Hummer. So the point of this post is that I need a find out if the bolt pattern of a 7.25 AAM matches any other axles out there. If it doesn't match anything out there, I want to get a hold of a factory front diff cover from any h3 or h3t so that I can beef up the front diff.
Thanks for you help guys.
Measure carefully - not a lot of room there for a reinforced cover, or at least as much as you might initially want. I believe there's less than an inch between the cover and the OEM steering rack mount.
bebe
Moderator
Dayton, NV
We did look at that - or, I did back in the e-bola days. The more effective solution would be a diff collar - but, like the KJ Jeep Liberty, which had the same issue, the case deflection occurs behind the axles from pinion gear riding up the ring gear.
Maybe using a collar with a high strength diff ring would be a more effective option. I would help stiffen the case from both ends?
http://www.bluetorchfab.com/Product/929/BTF-Corp-10-Bolt-Front-Diff-Ring.aspx
this is a 14 bolt version, they don't make one for the h3 front
Just trace the gasket, input into CAD, and laser-cut it from 1/4". Then start building the dome from flat plate...
They are not (supposedly) weak...they are total crap. Anything you can do to stiffen the housing is better than doing nothing at all. Great idea...it certainly can't hurt. Maybe you can somehow add something to beef up the snout, near the pinion area?
