05Mudiak
- Lake Charles, LA
OK I am working on my wifes cousins ugh ford contour, It was running like crap wouldn't stay running ect ect.. check fuel pressure it was not right changes fuel pump can ran a bit better, changed fuel injector pressure sensor no change. of course did plugs wires still nothing
oh the check eng light is not on.
OK so since this is the VCT 2.0 4 banger I figure timing belt car does have 110k miles. This is where it gets crazy.
changes the belt lined up the cams and all that junk. Started the car it ran great put everything back together put the surp belt back on. Started car ran like crap again. Took the surp belt off ran perfect. What could be causing this issue.
With the surp belt on car barely run spits and sputters seem to be running kinda rich. Belt off runs perfect.
I know the biggest problem is its a ford but I am trying to look past that
I am thinking maybe bad alt? I am pulling it off now to go get it tested. I have never seen this before I am lost ugh
