Need help replacing Fog Lamp assembly
Justanotherhemi
Mission,Texas
As the title reads I need help with a "how to" on replacing my fog lamp assembly. It went bad recently after it took a dip in water causing the bulb to melt onto the assembly. I have since purchased OEM GM replacement for both side. I tried approaching the 3 screws holding it on from the bottom with no luck. Any help would be greatly appreciated.
When I pulled my fogs out to replace with LED's I just removed the whole bumper assembly (much easier to do than you would think) then it gave super east access to everything and should be a cinch from there!
What in particular are you having problems whit??
Justanotherhemi
Mission,Texas
Thank you guys for your replies. I found a tech article by Mutant on installing a Boulder Accessories bumper. His how to was so detailed and pictures were a great help. It took me 2 hours of wrench time to take off, clean, replace fog light assemblies and re install. Thanks again
