Sneakysilver
- Midlothian Virginia
Ok so trying to bolt up my sliders and the bolts are getting stuck, my air ratchet won't even screw them in. Need to have them on by this weekend. Thanks in advance!
Are they the OEM sliders? If so, are you using the supplied bolts or your own?
Don't force them in, you wouldn't want to damage the inner thread in case you accidentally received the wrong bolts.
Share some photos if possible.
Oem sliders and I found a bolt from my buddies shed that seem to work but have it packed up for the night would welding thn on work just as well?
Welding is a bad idea, its a very simple job if you have the right bolts... Try a couple of different threads & see which goes all the way through.
Make sure you have someone helping you install them, you wont be able to carry the sliders in place and drive the first bolt in at the correct angle by yourself (but I guess you've already done that).
Let me know what happens, good luck.
Don't forget that they are metric. I don't recall the size. May help to lightly push a tap through there first.
