New toy Hobart 210 MIG welder
Finally got to start playing with my new toy. Been practicing for a few hours and dialing in the settings. My first order of business is to fix the roof riv-nuts that are spinning preventing me from removing the roof rails and plastic.
Like a kid on Christmas morning.
Happy Hummer
Wisconsin
Nice. I keep putting off buying a new 220-240v welder.
Have you enjoyed this one so far? I guess part of it is the sticker shock.
I got it as a gift so no sticker shock and it has been sitting for a while due to my work schedule. So far I've only practiced on the little weld nuts and think I have it dialed in. Practice welds have held up to over 40 ft/lbs on the torque wrench before the grade 8 1/4" bolt snaps. Can't wait to get to welding on the 3 next weekend.
Project #2 is to reinforce the Rancho lift trailing bars. The lift I bought from Panzer is going on soon and then #3 is the front carrier mod for the steering rack access.
Thats the same machine I use. Add a gas bottle and reverse the polarity...you can build a battleship with it.
80/20 shielding gas (CO2/Argon)...sometimes 75/25, really can't tell much difference. You can buy your own bottle and get it refilled locally. You can also order a new bottle off the net and add the gas as an option. There are many online places to get pre-loaded gas bottles, so shop around (Amazon, Northern Tool, Harbor Freight, Tractor Supply, Rural King, IndyOxygen, Cyberweld, blah blah blah)....
http://store.cyberweld.com/shielgas...12esBpt55hhKkuLrA181v-mRyg15Ykw_w1xoCeNzw_wcB
I use .030" standard steel wire (no flux-core), on a large spool. I run the gas pressure at 25-30psi. No real adjustments other the normal for wire speed & amperage. Polarity will need to be reversed to run the gas kit. Read the Hobart instructions...pretty simple, takes all of 5 minutes to flip two wires. This is standard practice for most welders when going from flux-core to standard wire.
I have the same welder and a large tank of 75/25.
Yeah I had the large tank for awhile. It required me to get a lease, and then exchange when it ran out...not a problem. But, eventually my lease ran out and I was facing to re-sign for another 5-years...something I wasn't real keen on. So I spoke to several other welders that directed me to get my own tank rather than lease one. The 80 cubic foot size can be re-filled, and I'm not locked into any sort of lease or exchange program. Its my tank. I fill it when I need gas. And if I decide to sell my welding rig complete...the tank goes with it (no messy lease-transfer paperwork)...no lease renew...no tank swapping.
Picking up a tank of 75/25 on Friday and gonna play some more.
Playing is the key...practice makes perfect. I use #4 & #5 settings a lot for 3/16" and 1/4". I've never used the 110 volt option but, its nice to know its there if I every have to do some portable welding somewhere.
