Not Hummer related but pretty cool.
We are just finishing up a major maintenance event here at our Tesoro refinery in Carson. These are some nuts and studs.
These are nuts and bolts that hold the channel head on a high temp high pressure heat exchanger. 900 degrees at 2000 psig.
The bolts are 4 inch diameter fine thread CMV alloy. Guess how much they have to be torqued to.
Yep, 29,000 ft lbs each, times 28 bolts, times 6 exchangers. It takes a full 12 hour shift to make 1 pass and 16 hours for the final pass on each.
Gunner_45
Texas
Holy ****!
How ****ing big is the socket or wrench that turns those bad boys?
As long as a man is tall?
High Five H2
West Texas
I work in natural gas, and i get to see some pretty big equipment too. it's pretty cool. those bolts are huge, though. dunno if we have anything like that.
Woodtick
Ilanoid, UP MI
I'm in the same line of work. It's 2015,it's ok to play with big nuts. A apprentice made a set of truck nuts with a few left over from a job,they were stolen off his truck in less than a day. Welded chain,they didn't fall off. Cool pics. This pic is of a snow/ ice melt heat trace on a high rise. The heat exchanger was low torque and small nuts. Fixing the glycol leaks on the pipes required a good size set of nuts. Yes I was tied off. Lol
twinmill28
Spilled Milk
Hey Rascole, any chance you drop about 10 of those in your lunch box along with about an 18" section of all thread?
I used the same setup to mount my glass HUMMER sign on the wall but the bolts just seem too small. I think these will work just fine to get my point across......
By the way, looks like you guys forgot the spring washers, it all needs to come back apart. If you don't have spring washers, how about rounding up some Nylon locking nuts??
I guess I now understand when somebody says "that guys got some big nuts"!
lol, they'd weigh more than me and I'm husky. (275)
Here is the side profile to show how thick the channel head/dollar plate is. One solid piece of metal.
Yep. Channel head is the thinner one that is part of the exchanger and the dollar plate is the "cap" on the end of it. Take the dollar plate off and you will see all the tubes that the process flows through, in this case diesel.
