Nuts & Bolts Thread
Instead of bugging Zach, Solarflare, and other guys who have info to everything GM every time I lose a bolt I end up messaging them or calling them to find out what size the bolt is, the thread pitch etc. I figured it would be a good idea to start a thread where if you ever lose a bolt share the size...It will make life a lot easier then PMing, messaging and calling, plus you share the info.
I lost some gas tank skid bolts so I guess I will start seeing Zach messaged me the bolt size. Thanks Zach!!
M8x1.25x22
HFH, M8x1.25x22, 19 THD, 18 OD, 10.9, GMW3359 (F/TNK SHLD)
I really need to stop misplacing stuff :emb:
DAMN IT! I dont know how but my tomp low profile shock bolt and spacer is missing where do I get a replacement bolt and spacer? I can run without the spacer for now I just need the thread and size specs to get something in there for now...PMed tomp and hopefully I can get a permanent replacement
does anyone know the bolt dimensions for the OEM UCP t case skid that mounts to the back crossmember?
CaseyS
Louisiana
Most of those UCP bolts are M8x1.25. Just go to home depot and pick up a small assortment of lengths and stick them in a ziplock in your storage hatch for spare parts. You can get grade 10.9 if so inclined.
