Oil catch cans
whylee
Reno NV
Did a search but nothing came up. After installing the Magnuson supercharger on my Alpha, I started thinking about installing a catch can on the breather. I dont want any oil residue to gum up the internals of the supercharger. I have heard some vehicles are really bad about this, but have not heard if the 5.3's have a issue with this happening. I know there are 2 breather tubes, 1 on each valve cover.
The right breather goes to the air cleaner tube, the left plugs into the supercharger intake housing. Just wondering if I should use a catch can on either or both of these, or run them to small filters and let them vent on their own or just not worry about it because its not a issue on these motors. There was some oil residue in the original air intake tube around where the right side hose ran and a small amount on the inside of the throttle body. Some of that could have been from a over oiled K&N air filter from the previous owner, just want to head off any future problems.
Im running a catch can on my Alpha. It has a transparent hose to indicate the oil level inside the can.
So far I can tell oil is getting in it as the indicator is discolored already!
whylee
Reno NV
There is another breather on the back of the left valve cover, or at least it appears to be a breather.
