GossamerH2
- New Jersey
HELP !!! My 07 H3 has been having problems with low oil pressure at idle. It started about 1 1/2 years ago after having the radiator replaced. A month later I had the thermostat replaced because it seemed to be running hotter than it used to plus the low pressure light started coming on which the Dealer said was because the engine was filled with sludge and he suggested I put a 1/2 Qt. of trans. fluid in it and run it for 100 mi. then change the oil. So I did but the oil light started coming back on 3 month's later. At first it only came on intermittently, it would go 3 to 4 months without it coming on then it would come on several times then stop but lately it's been coming on after it gets hot when idling. Also the last couple days here in NJ. it's been above 90 and the truck got really hot while sitting in traffic (a little above the 3/4 line on the temp gauge) I bought the H3 new in 2007 and have changed the oil every 3 to 4 months since I've owned it so I can't understand how it could've had a sludge buildup. I've changed the oil 7 times since it started each time either flushing it with motor medic first or the 1/2 Qt. of trans. fluid and drive it 100 mi. and I've also replaced the oil sensor sending unit as well as the cam shaft positioning solenoid but no luck it's still coming on. I read a thread on here the other day about the oil filter pressure release valve so I picked 1 up from the dealer and got 6 Qt's of 5w30 oil but I have no idea how to change the valve or where it's located. Has anyone else had this problem and changed the pressure release valve and if so A.) Where is it located and how hard was it to change B.) Did it help ? The H3 currently has a little over 115,000 on it and I just started a new job that requires putting a ton of miles on the truck so I need to figure this out and get it fixed soon ! Thanks,
