Searched for an hour and can't find how to remove the onstar antenna. From what I can gather it's just some compression clips and you just pull and it will pop out. True????
So using a USB borescope, I found the little 10mm socket head bolt under the antenna. Had to remove the passenger side headliner a bit to reach it, may have been able to push the 3 springs clips in to push it through but removing the bolt was easier. Now to figure out how to remove the cable connector. Looks like little BNC connectors but it doesn't look like it seperates.
