BarryC
- Pennsylvania
Good day all,
My H3 has been coding the Dreaded P0300 code! (Random cylinder misfire)
I started with the most obvious and relatively cheapest fix...new plugs.Still coded...so next I replaced the Coil packs,still codes! Only codes when It idles?! Runs perfectly fine..no misses or poor acceleration etc?!! I then cleaned the throttle body as well...still fkng codes ???!!! Doesn't appear to have any vacuum leaks either...and new fuel pump a year ago...so fuel pressure is also good! Any suggestions would be appreciated
