Passenger Headlamp Harness
06-3
Edwardsville ,Illinois
I cannot access the passenger headlight because of the Volant box shoehorns so tight in there that its not possible to reach the harness.....so I am guessing plan B has to be grille removal ? I have not had the grille out yet....is it possible to loosen left side and pull out a little or just pull the whole puppy out and be done with it ?I have been f@#$%^ around with it trying to reach the harness another way and doesnt appear to be happening...:huh:
SolidusJ
FT. Carson, CO
Then the headlamp is held in with 3 bolts and the front marker light will come off with it so be careful when pulling it out.
Yeah don't get too freaked out it's just 4 bolts for the grill plus a few clips then three bolts pre head light/ side marker setup
06-3
Ok , thanks guy's , that sounds easy enough...going to do that today , the Volant is a nice CAI kit , but once installed the grille will have to come out to get at the passenger lamps.
06-3
Grille almost coming off..what am I missing..someone said clips , are there clips under each far corner right next to the body itself....**** dont want to pull and tweek in the wrong place and break it...:huh:I have removed two bolts in front of the radiator topside...and two bolts one on each side down below that are recessed and take like a 8 er 10 inch extension to remove..and and a hex nut on top of each corner....thats where I am now...
Crap...disregard ..what I had in mine wont give me access I need...I have to pull the airbox back out which is a drag....aw well....
