Babyjohn460
- Burton, OH
Hello all! Ok so, after all the recent repairs (trans, torque converter, trans cooler/radiator, heated seat switches, ball joints and alignment) I decided to pick up a Superchips tuner last week for the Alpha. This past weekend was a fairly good test, 8 hour round trip camping trip with loaded toy hauler on the back. The tuner made a noticeable power and transmission difference. Not sure if it's a $350 difference, but a difference none the less. Was able to stay steady at 65-70 mph no problem. Figuring out the unloaded fuel mileages this and next week to see if it goes up or down with the tuner on different settings. Since the tuner was added, I had a few things I was hoping someone else has some info on.
-One thing I didn't like that was a selling point for the tuner was it was advertised as being able to change your axle ratio/tire size in the computer to adjust your speedo. Unfortunately, it seems GM doesn't allow this adjustment without a complete PCM retune, is this correct?
-Already have a high flow factory replacement air filter ordered to help get some more air into the intake. Has anyone played with the intake to get more horsepower? If so, what did you do and was it worth it? Seems like the intake system on the 5.3L is pretty no nonsense as it is. I've seen some people with AirDoc "systems" but not sure if they're worth the $$ since the factory air box is already, for lack of better term, a cold air intake. Are there any factory intake hacks to get more air flow?
-And lastly, I've been kicking around the idea of chopping off the "S" piping from before the muffler back and bending up a straight pipe from above the rear axle and exiting the passenger side of bumper. Has anyone done this on an Alpha? Notice any performance difference or is it all noise? How much louder was it? Alittle reluctant to do this as I'm not sure if I want the exhaust noise bouncing off the camping as I drive if it's a lot louder.
