pinion Master install kit
Sennin
South Africa
Sennin
South Africa
Ok thanks. So now the question is how do I make sure I get the correct kit for my setup [emoji85]
Sent from my SM-N9005 using Tapatalk
They are out there. The 09+ rear ends do have a slightly larger pinion gear. the fronts should be the same across all years though.
Here is a link on rock auto to master rebuilds
http://www.rockauto.com/en/catalog/...747,drivetrain,differential+rebuild+kit,18601
Here is the master overhaul from yukon for the front
https://www.yukongear.com/partslist...CatID=27&CatName=Master+Overhaul+Bearing+Kits
And the rear here, this should be the correct kit for the 09+ kit with the larger pinion.
Yukon's website makes it easy to search by axle and make, and should point you in the right direction of the correct one.
I know since you're in SA it might be difficult to get everything in a timely manner. Hope this helps.
Sennin
South Africa
Just to close of this. Got the parts. And had it installed along with my new 4.56 ratio gears. And I should have done it years ago. Totally different beast
