Potential H3 purchase.
Jrgunn5150
Ionia, Mi
Ok, so, I'm new here, and I'm sure you all feel your Hummer vehicles are great :), but please, try to be objective lol.
My name is J.R., I live in Michigan. I currently own a variety of vehicle's, some toy's, some project's. 2 dailly driver's between my GF and I. Last year, I bought an 08 Trailblazer LT, with the 5.3. I've since lifted it 3", added 33" tire's, put 4.56 gear's in, and added a rear Detroit locker. It takes me on long road trips, it takes me to offroad parks, it sometimes hauls trailers for me. It has heated leather seat's, XM Satellite, 2 position memory seat's, etc etc. It's a comfortable, reliable, recreational wheeler.
Now it's time for my GF to get a new vehicle, and she would like the same thing. She enjoy's the Trailblazer and want's something similar. There's are benefit's to having two of the same vehicle, but there are con's also, so I'm researching a little wider, as we have a bit more disposable income now.
I'm looking at, Envoy Denali (5.3 also), the H3 Alpha, and the Nissan Xterra. Having a frame, low range, and some kind of aftermarket is key.
Now, when she's ready to move on, this will become my vehicle. I'm 6'5, 260 lb's. I barely fit my Trailblazer comfortably lol. I'm concerned the H3 is smaller yet. In offroad capability, I"m sure it win's hand's down stock. However, I'm no stranger to modifications, and no afraid to make them, so that's not really the deciding factor.
What is, is reliability, and part's availability. The Xterra, they've been making since like 2000, and still make. I'm absoultely certain I'll be able to get parts for twenty year's for it. I'm also certain it's not as comfortable as the other two. The Envoy, well, they've already discontinued many part's for it, and the aftermarket is incredibly small. The H3, it at least share's a base with the other GMT355's, so hopefully chassis/drivetrain part's are a non-issue. I'd be buying the Alpha, and I'm certain the 5.3 can run 300+ without issue. So, school me on the steering rack and diff failure's?
A Sub-100k Denali is 10k ish, a sub 100k Xterra is about 13k ish, a sub 100k Alpha is about 17k ish. So, for my extra 4-7k, what kind of problems am I looking at in term's of common failures under moderate wheeling use?
Haven't had either of the other two vehicles though I did buy my daughter an Envoy which she has really enjoyed. Our H3 Alpha has been extremely reliable. I have only had to wait for one part on backorder. 128K miles so far.I am 6' 220# and I need the seat all the way back to slide in. Steering rack aftermarket brackets fix the rack issue and the cast iron diffs have not been the problem of the aluminum ones, but they could be more robust.
Jrgunn5150
Ionia, Mi
Thank you! That's what I am looking for! I have to tilt the seat back a bit in the Trailblazer to keep my head off the ceiling lol. But it is comfy. Do you do much wheeling? I live in Michigan, so my terrain is muddy, hill climbs, sand, clay, gravel. Nothing really high traction, nothing I need super duper low for or anything. Just decent approach/breakover/departure angles.
If you wheel the h3, the front diff will need to be repaired or replaced at some point in time. Even the cast iron ones. The aluminum ones tend to blow up....the cast iron ones tend to blow up less and have more internal issues. Lots of us have been through more then one front diff, me included. On the other hand some are still on the original with lots of wheeling and mileage. I know that sounds hit and miss but just a heads up the front diff will most likely have to be serviced at some point the vehicles life
Jrgunn5150
Ionia, Mi
Are the seals and bearing's still available? Are you busting carrier's or something else? Do all Alpha's get the cast iron front pig, or is it an 09 up upgrade?
All alphas have the cast iron. I never busted a CI, one diff the pinion bearing went bad and the other the lash settings were out of spec due to lots of wear on the gears. The last time I checked AFAIK the seals, bearings, and gears are all available.....still haha
Jrgunn5150
Ionia, Mi
That's awesome information! What kind of mileage did you have trouble at? Is your front locked as well as the rear? Any problems with shaft's or hub's?
Pinion bearing was around 60k, wouldn't have known about it, but I swapped in aftermarket bushings on the front axle mounts and that's when I could hear it. No idea the other since it was used. Front wasn't locked on the orginal, it does have a locker now. No problems with the original shafts or hubs.
Schwarttzy
Rockford IL
I've been around the block a time or two. If you know how to wheel correctly the front differential is fine. It's the old Dana 30 and 35" tire debate all over again. Throttling up... is the last resort, most tend to try it first. Same thing with the steering rack. When off-road you never force your steering wheel one way or the other. Get your tires to do the work by slowly spinning them a little bit. Learn how to bump your vehicle. Bumping is understanding how suspension anti-squat works to unload the suspension along with timing to hit obstacle so that the vehicle feels the lightest it can.
Rock crawling is a marathon of art and finesse, not some brute force sprint.
Once you understand that, the vehicle is plenty tough. Personally I'm in the mark for a 09 / 10 H3 Adventure / Luxury Alpha so that I can tow a reasonably sized travel trailer. I love my 06 to death too, just wish it had more power.
Jrgunn5150
Ionia, Mi
I don't rock crawl, not a lot of rocks here. Rut's, tree roots, stumps, but not really rocks lol. I'd love to visit Moab, but a three day drive there and back mean's I keep putting it off.
I thank you guy's for your advice and insight!
Woodtick
Ilanoid, UP MI
90% of my wheeling has Been in Mi. My 06 is still running a 100% original front end. I do more of a overland type wheeling. I try to stay out of the skinny pedal like mentioned above.
We have wheeled it fairly extensively but not in the last few years. When in CA we did trails like 2N17X, Cleghorn, Anza Borrega, lots of Mojave desert ad Big Bear mountain trails. It was a mix of sand, rocks, ledges, etc. Also did lots of backwoods trails in the Piute Mtns on hunting trips.
Jrgunn5150
Ionia, Mi
I think that pretty accurately describes me. That's why I can wheel a Trailblazer on 33's around successfully, I'm not climbing 5 ft vertical rock walls lol.
We are going to go look at some of the different vehicles, my GF prefer's the H3, I don't like the price lol
Woodtick
Ilanoid, UP MI
A V8 Cammander is worth looking at. We own a 08 and it's been good to us since new. The 3 is more capable off road but the Cammander does ok and is much better on the road. Well over 300 HP............
I've not had any issues getting replacement parts. Ironically, now that the H3s are a bit older there are more parts available than there were in 2010.
Why don't you look at an H2?
Jrgunn5150
Ionia, Mi
Too big for the trails we go down, my Trailblazer has tree rash now from a tight squeeze. Also, it's just the two of us, no need for a full size vehicle taking up space in the driveway that barely fit's our current vehicles, and, while I haven't actually priced them, I bet they are firmly out of our price range.
You can find ones for about the same price as a nice condition H3, and if you're looking at an Alpha H3 you can easily find a nice H2 for the price. That was the case the last time I looked around here in Utah anyway.
H2s are affordable but that's not what you want, understood.
H3s have a decent aftermarket for replacement parts though not for upgrade parts. Dorman and others are making parts for the H3 and the Alpha is the 5.3 so plenty of parts are available. I had more parts availability issues in 2010 than I do today.
I think the reliability of the H3 is decent. It's not the Toyota pickup (official ISIS vehicle) reliability, but it's pretty strong. My particular H3 has been below average and/or I'm particularly picky on making sure my H3 is operating just right.
Where I see a strength in the H3 vs others like the Nissan is that owners want to stick with the H3 and they figure out ways to put in upgrades, whether a 6.0/6.2 or even a Cummins. It's a terrific platform for upgrades, even if you choose to go the custom route.
