Powder coat or bed liner?
Fish
San Diego, CA
My brush guard is showing some wear and needs a fresh coat of something. I havent got a quote for powder coating yet but I was thinking for a fraction of the cost I could use some bed liner on it. What do you all think? What are the pros and cons of each?
I was also thinking of using bed liner on my chrome fuel door to make it black, will that work?
Bed liner all the way! It gives a rough look. I use rustoleum bed liner. It has held up great on everything, especially my rims and they see A LOT of abuse. Another pro to bedliner is the easy touch up. If you hit something and need a touch up bedliner blends and it looks like one coat. Sometimes regular spraypaint on touch up is noticeable, especially if you chipped the brushguard when you hit something.
Satin black (not flat) Duplicolor spray paint is a good match for powdercoat touch-ups.
AbsntMnded
Pennsylvania
I personally like the textured look. Has anyone had any problems with spray-can bedliner fading? I used this on my light bar recently, and would like to do my brush guard.
Same question with Line-X. Any fading after a year or two?
Edit: Looks like there is also Line-X Xtra for additional UV protection.
08SolarFlareH3
Super Swampers
Finger Lakes, NY
Bedliner is quite a bit cheaper then powder coating and would be a more durable on something like a brush guard. I say have it sprayed in Line-X or Rhino Liner. A DIY bedliner is a cheap alternative (like the Rustoleum 06 H3 posted) but it is not as durable as the professional grade stuff.
Fish
San Diego, CA
I personally like the textured look. Has anyone had any problems with spray-can bedliner fading? I used this on my light bar recently, and would like to do my brush guard.Same question with Line-X. Any fading after a year or two?Edit: Looks like there is also Line-X Xtra for additional UV protection.
When you say textured look which are you referring to? They both are kinda textured.
Are you talking about buying professional grade stuff and doing it myself or having a shop apply the bedliner?
I havent. My rims are still shining but they do need a good clean up every once in a while. The mud and dirt were on the rims for months but if you use a good product they will shine again
FOXedupONE
Blue Ridge Mountains,VA
I did my mirror caps and grille in lineX. The parts are significantly heavier then they were before and I doubt it will ever have to be touched up. But it's not that cheap either. Linex did say they could do my brush guard also for a super tough finish that also had a topcoat of UV protection.
Spray can bedliner stuff is probably fine for something you can easily take off and respray again once in a while. Plus it's under $10!
Fish
San Diego, CA
I did my mirror caps and grille in lineX. The parts are significantly heavier then they were before and I doubt it will ever have to be touched up. But it's not that cheap either. Linex did say they could do my brush guard also for a super tough finish that also had a topcoat of UV protection.Spray can bedliner stuff is probably fine for something you can easily take off and respray again once in a while. Plus it's under $10!
So it sounds like powder coating and professionally applied bed liner may be the same price..
I think it really comes down to personal preference. Cheap vs. not cheap, line-x vs. powdercoat. The cheap equivalent to line-x being dupicolor bed liner and the cheap equivalent to powdercoat being spray paint. This is a similar discussion that we have when we talk paint vs. powdercoat on wheels. I think it comes back to personal preference on both budget and the look of the finished product. Both have their advantages.
BTW, a well done powdercoat, like Rocky Road puts on their sliders, holds up very well. I touch it up with Rustoleum Hammered Metal Black spray paint and find it blends pretty well. I've seen poorly powdercoated sliders on other trucks where the powdercoat comes off in sheets when it hits a rock. The RRs don't do that.
I'm sure I'm oversimplifying here but it sounds like you get what you pay for in terms of durability, and then simply choose whether you want a rough finish (bedliner) or a lightly textured finish (powdercoat).
Fish
San Diego, CA
POR 15 is paint right? I dont want a painted look...
I'm going to get quotes for both soon and go from there. I'm leaning towards powder coating. I'm not worried about making touch ups since the brush guard wont see to many scrapes like a rock slider.
One last question that seemed to got overlooked in my first post, can you use bedliner on chrome? If so is there any special prep work that needs to be done?
Fish
San Diego, CA
UPDATE:
I got quotes for powder coating and I was pleasantly suprised. They said $150 for the brush guard and $25 per u-step so it looks like I am going for the powder coat. Its from a reputable local shop, I went to high school with the owners son so if they have been in business that long they must be doing a good job. I didnt get any quotes for bedliner because I was always leaning towards PC'ing but thought it would cost more than it does
Zach hooked me up with a super good deal on a color matched grille so tomorow I will take the brush guard off and take it in, then replace the grille :thumbs:
Matt,
With them doing them steps, do they sand blast them first or just coat over the existing surface?
Fish
San Diego, CA
I got the steps of craigslist, the previous onwer spray painted over the original coating..that being said they told me they will sand blast them before powder coating, but they said it is very hard to sand blast the original powder coating off ( unless you want to spend some $$$) So they will sand blast everything and assured me the new powder coating will stick to the old powder coating good.
Scarsman
Monroe, WA
Matt,
They will have to sand blast them first. That's one thing about powder coat, is you cannot touch it up. You have to remove it and start over.
If you get the textured black, the place here called it mini-tex I think, Rustoleum makes a textured paint that is a dead on exact match, so you can touch up scratches really easy.
benlaud87
Maryland
I guess youre going with powdercoat, I had my handles and grille line-x'ed about a year ago and its held up great. I also tried some spray on bedliner earlier this week to touch up some trim. It was plastikote bedliner in the type of can with a trigger for spray. I like the look of it alot better than any other type DIY bedliner ive used before.
The only thing ive noticed with line-x is if you dont get the extra coating or whatever they call it then it will fade in the sun over time. a quick coat of paint and it looks good as new again though.
I use Rustoleum Hammered Metal Black to match my Rocky Road powdercoating
Sent using Tapatalk
Fish
San Diego, CA
The PC I got is the mini-tex, it matched the factory sliders and my roof rack pretty good. Good to know about the touch up paint, my sliders need some touch up. I didnt drop off the brush guard til yesterday so it should be ready by end of week.
