door locks and driver window stopped working after the truck died while I was installing a nav unit. Checked the fuses and relays. Even disconnected the battery for 30 minutes and they still don't work. 3 other windows still work fine
nvm. fixed it. let the truck sit with the batt disconnected for 40 minutes then started it and waited for all the lights to go off and tried the driver window and all is working
