one_less_prius
- Golden, CO
I have always liked the idea of electric steps so figured I would give the AMP Research PowerSteps a shot on my 2008 Hummer H3. I decided to buy and install them myself. Here is a run down of my experience and overall thoughts on the product.
Install:
When I opened the box I was delighted to find all the parts separated and marked in clear bags. The kit I ordered included the steps, brackets, wiring harness (with connectors) and lighting kit. AMP includes a small instruction booklet that is more than enough information to install the kit. The instruction booklet works for both H3 & H3T as there is a couple differences during install. After a few hours and a couple cold ones I had the PowerSteps installed and working. The lighting kit took another hour or so as you have to plumb those wires separately. Overall it is an easy install if you are somewhat mechanically inclined.
Product:
I am extremely satisfied with my PowerSteps. I love the way they look and overall functionality. The steps are very convenient as they are there when you need them and tucked away when you don't. I was worried the step would hang down and impair my off-roading capabilities but they don't. The steps actually tuck away above the frame rail and completely out of the way (even higher than the stock running boards). The only issue I experienced was the steps are a little noisy when they operate. It makes a slight thud when the step stops at the top or bottom (See video). I don't mind the sound and it actually reassures me the step is up before I drive. Otherwise the steps are very quiet and do not make wind noise or any noise for that matter while I drive. I would highly recommend them to anybody considering this upgrade.
Video of operation:
Hummer H3 AMP Research PowerSteps - YouTube
Install:
Product:
Video of operation:
