S
SedonaBound
I used a Metra GMOS-04 harness as specified for OnStar systems to install a new Pioneer head unit. This harness gets direct battery 12V power (i.e. not accessory power) and has a processor that controls the head power, warning chimes, etc. per data from the BCM. The new head unit works great, but the Metra harness is not turning it on/off dependably with the ignition and I'm hoping someone has dealt with this.
About 30% of the time, I have to turn the ignition on/off twice for the head unit to turn on. About half the time, it doesn't turn off until a full minute after the key is pulled and door is opened. It seems to be looking for an on/off pulse sequence that's out of synch. Metra tech support told me to pull the new head, re-install the OEM radio, and go through the full on-off sequence to reset the BCM's radio status, and put the new head back in. I did that, and it didn't correct the problem. Did it again and also disconnected the battery. No joy. I also asked Metra if I could just bypass or parallel the power lead from the Metra box to the head by directly tapping a switched circuit; the tech said no. The tech spt seem to read from a list and can't really discuss alternatives. The seat belt, door, and key chimes aren't working right either. I bought the harness with the unit at a Best Buy 70 miles away, so returning it is a big deal. Any ideas?
I've had other issues with the Metra harness too. Next time, I'll pay for the installation; this has been a royal PITA because of the harness.
