1sBtrThnN0ne
- Amsterdam, NY
Been having an ongoing problem with my 06. The truck wants to pull hard to the right everytime I let go of the wheel. Also there is a shaking in my steering wheel. Every so often I would here a rattle (almost like a heatshield) when turning left or right and it sounded like it was coming from the drivers side.
I put the aftermarket steering rack bracket kit in. Replaced pads and rotors. Noticed a leaking axle seal on drivers side so swapped the seal and the whole half shaft while under there(thought maybe a bad cv joint). Changed the front diff fluid. Rotated the tires(drivers side tire was worn more than the others and since the rotation I haven't heard the rattle noise up front).
Still no luck and it's progressively getting worse. Next thought was maybe wheel bearings or tierods? Any thoughts?
