- Meridian, ID
Alright, Im a noob when it comes to Ram assist and even with doing some research I am still a bit confused. How tough would it be to adapt this to an H3. All this steering failure talk and the fact that my steering rack has way too much play in it I want to upgrade it. Tie rods arent a concern. Those are easy to beef up and changing a tie rod in the field doesnt worry me one bit. Its just losing the rack is what I fear. So, I have thought of taking my current rack thats sitting in the garage and beefing it up. flexible tube lines to help with movement but my main goal is to prevent movement. Getting rid of the rubber mounts on the rack and putting in a dense type of bushing, some hunner mounts too. My main question is what can I do to relieve stress off the rack. Putting in a new one and retrofitting a new one/stronger one to the stock mounting location is a PITA and may interefere with the diff, all I wanna do is relieve the stress on the rack and make the rack handle some abuse. I havent broken one yet and thats probably because I try to avoid turning into boulders or forcing the steering where it doesnt wanna go. Will ram assist pull stress off the rack?
This is not going to be something I jump into right away but the sooner I understand it the better off I will be, I researched and feared of a spring over for a year but finally did it. Now I am moving to the front but I gotta learn a bit first
While I still believe the H3 is capable in stock form it has its flaws, like every other rig, and I wanna start ditching the flaws and coming up with some solutions.
http://www.4wheeloffroad.com/ultima..._2011_ford_f150_ecoboost_part_4/photo_10.html
I saw this for an IFS steering solution but its all hydraulic so if it fails going down the road your ****ed....
Lets stir up some conversation.
