Rascole's ScorpWorks H3/H3T Front Axle End Supports install,
In addition to my front end rebuild I installed the ScorpWorks H3/H3T Front Axle End Supports. The install was straight forward. You will have to pull the axles out but that is the hardest part. All the bolts are easy to access and remove. I would suggest loosening the diff crossmember bolt to get the holes to line up nice and easy.
Nice improvement - these are a common failure point and this should be the last time you have to do this work. I replaced 4 passenger side ones and 2 driver side ones before I installed this permanent fix.
