H3 Reading/Map Lights not working on H3
Hardware
Cumming, GA
I just purchased a new to me H3.
Can anyone help me with this? I have tried locating a fuse, can’t? Is this a common issue? The cabin lights are working fine just the reading lights are not. The PO put LEDs in so don’t know if that is an issue.
Thanks
SolidusJ
FT. Carson, CO
Could you use a multimeter to test it? I would assume if the center lights come on when the doors open. Then the other set should with no issues unless the LED's gone bad.
LEDs are polarity sensitive so try pulling them out and reversing them. Or just put in old fashioned bulbs.
