Rear window switch not working
Dudley
California
Hello back passenger electric window does not work if both window switch does not work and driver master switch does not work can I rule out that it’s the Switch that’s bad and replace the window actuator motor thanks for your help
MilamJR
Alabama
I think that would be a safe assumption.
Reloader
Montana a free state
Could be bad wiring at flex point at door jamb. Remove inner door panel and verify by applying 12 volts and ground to window motor connection pins. Apply one way for up . Reverse connection to go down. If works, its a power supply issue.
