Rigid Industries Fun!!!!!
SolidusJ
FT. Carson, CO
Good news
I got my 40" Rigid Industries LED bar on tonight and the two 4" will be put on tomorrow!!!!!
Bad news
So this is the second time that my Axxess GMOS-02 or which ever one I have has died. Just like last time my onStar light is red and my radio won't shut off. Last time I just went to Best Buy and swapped the old one and good ass new. Anytime I doing major work like adding a new sound system or LED's this happens. Disconnect that battery for and hour and clean this and blow that and still jack. Anyone else run into this problem as well?
that looks lousy on your truck. You should probably sell it to someone on the forum for $100 or so and recover some of your money.
Okay, that looks awesome! Very nice addition to your truck.
SolidusJ
FT. Carson, CO
:roll: Come on I finally got REAL off road lights!!!! Oh ya before I forget, I want both the 4" light to be on one switch so I was thing that if I just link them together at the switch it should be fine right?
I linked my D2s together after the relay, that is between the output side of the relay and the light fixture. So, from the relay to the lights I spliced the two wires so I still had two connectors, one for each light. The wiring they supply should handle the load no problem.
I really wanted a 40" bar too but I couldn't make it work. Where are you putting the 4" lights?
SolidusJ
FT. Carson, CO
Thanks for the head up on the wire. On the front there is 1" from the LED to the mount so I'll do the same with the rears and keep the center empty, they are Fog LED's so I know what's right behind me. I picked the whole set just over $1,400 altogether at Amazon. The 40" went for $1,029 about $200 less then what they go for.
SolidusJ
FT. Carson, CO
All done!!!! Now I just need a rack and it'll look right and have somewhere to put the spare tire.
SolidusJ
FT. Carson, CO
Some show off shots.
