Roof rack lights question
algin5109
Richland N.J.
I did a quick search and didn't find a lot of info so I gotta ask. How did those of you with roof rack lights actually bring wires into the cab. If there is a roof penetration what did you do to seal it. Pics would be sweet too. Thanks
Open the door and pull off the foam rubber trim (it's not glued, you won't damage it). Unscrew the two screws you'll see along the side of the A pillar. The trim is held in place with two additional snaps that are prone to breaking, which is why so many H3s (and H2s) have wind noise problems with the A pillar trim.
Here you can see one of the snaps and it is broken into the female end.
Full view of the A pillar and the two snaps. You can also see where the two screws go, on the right side of the A pillar
