Somethingbigandorange
- Arizona
Looking for some advice. Idling rough, losing power, check engine light flashing. Throwing P0300. Misfire count on cylinder two is ten times the others but all are showing some misfires. Fuel is 60psi even when sputtering. Plugs are clean and gapped correctly. Throttle body is clean. Air filter is clean. No fuel smell or smoke out of the exhaust.
When it it first started I revved it a few times and it settled down. Recently got worse and is doing it full time. Since intake, plugs and pressure were good I thought it might be injectors. Nope. Changed them out still does it.
Suggestions?
Suggestions?
