Rough idle
algin5109
Richland N.J.
Started to notice a bit of a rough idle when I release the gas pedal. Tach drops down to around 600 and engine stutters for a sec then idles normally. So I just replaced the plugs and didn't make a difference. Only seems to happen when I get out of the gas. Any advice. Thanks.
Man, im sorry....
I have an 06 3.5L too. I changed the spark plugs and coil pack and still had a check engine light w/ misfire and a rough idle. Took it in and I had the dreaded cylinder head issue
you guys are lucky then. Maybe a dirty MAF sensor or TB? I threw the codes and had the bad head and its getting replaced as we speak. Hopefully it isnt anything too crazy
Start with two or three gas tanks with Techron added and/or run Chevron through it, if you don't already. That clears up rough idle for many. I would also recommend cleaning the throttle body.
My truck was doing that as well and later down the road I ended up replacing the head. I would periodically get CELs with the code P0300 (general misfire) but I did not necessarily get those codes when it ran rough. In fact, the CELs never seemed to correspond to a rough idle.
JonBishop
Glendora, CA
I had that same thing happen, a case of bad gas and broken motor mounts, just like Alex said the chevron techron additive knocked it out, and my motor mounts made it really shaky and threw a misfire but when I went an took it to Zachs shop they helped me sleep at night knowing it wasn't the head... Sry 06 H3 hopefully u get ur Hummer back soon!
D
Dennis
So did mine and I did the exact same thing..cept, mine finally, after maybe a year of doing that idle thingy..it threw a code, indicating a cyclinder misfire..it will happen sooner or later..I got a new head
..but read this post in another thread
http://www.hummer4x4offroad.com/for...-cylinder-head-(&p=37589&viewfull=1#post37589
