Side Mirror Motors
RWildRide
New York
Does anyone have a part number or anywhere to get just the adjustment motors for the side mirrors? Its relatively simple to reach compared to replacing the entire mirror assembly for a bad motor. I cannot find an Acdelco P/N anywhere.
Happy Hummer
Wisconsin
I usually check the salvage yards for H3, Colly and Canyon....
That is how we discovered the innterchange between each.... for passenger side door controls.
Have you taken the assembly apart to inspect the motors and wiring? It might be that the wires or connectors have corroded and can be revived with some soldering. Not an uncommon rust-belt issue. I had it happen on a vehicle once ..but only figured it out AFTER I went to replace with an expensive new heated mirror (not an H3).
RWildRide
New York
It moves in all 4 directions however the motor is slipping up and down. If I gently push it the motor catches and will move but slowly. Definitely internal to the motor sadly and was hoping to just replace the motor but I see that its not that simple...
