I want to make sure my rear brakes are operating within their normal temperature range and that they are not dragging. I just checked and adjusted the parking brake, cleaned the pads/hardware, and lubed the slider pins.
Before i replace the calipers (for a stuck piston), could someone tell me what the rear brake disc and rear caliper temperature temps read after mild driving? I drove my H3 for about 15 minutes at about 25 mph with limited stops. Using a laser thermometer i am getting about 120-140 degrees on the rotors and pads. Both sides are similar. That seems high to me for but I may be wrong.
If any of you have a similar tool and could check your rear brakes and let me know your temps that would be great.
