Sunroof drains
UPDATE 8/27/2012 -- Sunroof drains
UPDATE: We had a pretty good rainstorm and my wife found out when she went to work that the sunroof had leaked again. I had cleaned the front and had hoped that the rear drains were not plugged. Well, they were. According to the service manual, the rear drain maintenance is a huge project that involves dropping the headliner. I was NOT going to do this if I could find any alternative. Luckily, I did. If you remove the side panel trim (upper and lower) from the back, you can access the lower end of the drains. I removed them (similar plug to fronts), and again opened up the hole and cleaned out the gunk. While not ideal since you are pushing any obstruction the "wrong" way, I used air and a snake from the lower end to open them back up. All is well now....I hope. Sorry there are no pictures, but I wasn't in the mood to make this a photo shoot. I just wanted to get it done.
Unless you just have an unbelievable amount of time to waste and enjoy contorting your wrists in about seven different ways that God didn't intend just so you can loosen a 5 cent connector two feet up under your dash, KEEP YOUR SUNROOF DRAINS CLEAR!!! I didn't and paid my price. Here's what little I can share to make the job a little more bearable.
I'll start from the END first. This glob of stuff that looks like dog crap is the slug of gunk that came out of my sunroof drain. Not shown is the sand and rock that also plugged the far end.
First, I was terrified of accidentally disconnecting a hose somewhere when attempting to blow the junk out, so to reduce, though probably not eliminate the risk, I catheterized the sunroof opening first with a piece of silicone tubing that had roughly the same O.D. as the drain's I.D.
Compressed air didn't work for me, even up to 100PSI (note: I wouldn't have tried 100PSI without the silicone hose inserted into the drains. Serivce manual says 35PSI or less). Next thought was that I could snake it out using a piece of steel cable. No such luck. If all you had was dirt, I'm sure this would have worked great, but as I later found out I was pushing on a rock at the bottom.
Not really many pictures of removing the lower end, but you need to find where the drains exit through the firewall. On the driver's side, you are looking for a black semi rigid line that plugs into a rubber fitting as shown below. Passenger side tube was white. On the driver's side, if you're scrawny like me, you can reach up far enough and just pull the connector out of the firewall. If you're at all in shape and have anything resembling arm muscles, you'll probably never be able to fit your hand up in there. Only time in my life being a wimp has come in handy!
Once that's disconnected, use your air or snake to clear it. On the passenger side, you'll need to lower the glove compartment, remove the end panel from the dash and the HVAC vent. Then it's just a matter of getting pack there to pull the fitting out of the firewall.
The picture below shows the factory plug. I have absolutely no idea why it's designed this way, but most of the exit is closed off with only a small "X" shape cut into it. This design makes it great at catching any gunk that does find its way into the drain instead of it just passing through.
While it's out, remove the extra material as shown below to open up the exit. Hopefully that will help in the future. It doesn't have to be pretty. Just use whatever it takes to open it up.
Avoid all this and just make sure you keep the sunroof area clean. Better yet, delete that option on your next vehicle. Unfortunately I had to order the sunroof as part of a compromise with my wife. She got leather and sunroof, I got the offroad package and 5-speed. :)
Sunroof. Yeah...not impressed. While I haven't had any "plugged drain" issues...mine has never really worked correctly since day one. I usually have to hold the plastic wind deflector down with my hand so it will fully close. For some reason it has two stops on the open operation...one about 4 inches from fully open, and the other at fully open. Not sure why this is. I mean...if you want it open...you want it fully open, right? (probably some lawsuit thing).
Also, the plastic wind deflector makes more wind noise when I let go of it...than it does when I'm holding it down. Which begs the question...what is this thing for? The sliding rail mechanism makes a gritty grinding sound during operation...no matter how much lube I use on it. Lastly...I thought the "moonroof" option would be cool when wheeling...but experience has proven to keep it shut unless I want a mud bath.
Normally I would take it to a GM dealer since I'm still 70K miles under warranty...but, I'm sure they would say that the SAS has modified the sunroof, so I would no longer be covered. So I just leave it shut.
Xlr8n
Midwest
A 3/8 drill bit will take the X shaped flappers out of the rubber grommet nice and clean. You can gain a bit more access to both grommets by removing the dash side access panels. Just be careful not to break the hard line.
If you are flexible enough, it's a 15 minute job start to finish for both front grommets. Just did this to mine last week and had a bit of crud in one side as well. The water now flows out like a garden hose!
4speedfunk- Sounds like you may have some grit or gunk stuck in your sunroof tracks. Might have to go to a sunroof guy to help clean the tracks good, but once clean you should have no issues with operation.
cbetts
NERD!!!
Rancho Palos Verdes, CA
I learned the hard way as well. Fortunately, I was able to blow the gunk through. It is amazing how much mud can get past the sunroof glass seal. Here is what my truck looked like after doing some whomping.
I was getting mud dripping on the inside.
This is what finally came out with the air hose.
Since I have on-board air, I will be making it a habit to blow out the drains after every mud run. I do not want that surprise again.
Nice writeup. I've been free of drain issues but I rarely open the sunroof when offroad as I don't want to encourage dust into the tracks or drain tubes.
4speed - not sure about your truck but whenever I open my sunroof the whole way I get really bad wind buffeting/wind throb. When open to the first stop I never have a buffeting issue.
Xlr8n
Midwest
I always crack a rear side window a couple inches to silence the buffeting.
As alrock stated, it shouldn't be buffeting unless it is going past the first detent stop to the fully open position. It should stop about 5-6 inches from fully open and you can run it that way down the freeway with no buffeting at all. If you press it again and go fully open, you get all kinds of turbulence.
IndyHummers
Murfreesboro, TN
Sorry for the old thread. Is it really necessary to take off the lower plugs or is that only if you can't get the gunk out? My plugs are totally plugged and water pools in the channels of the sunroof.
If you're able to use compressed air or snake the gunk out, then no it's not necessary to remove them.
IndyHummers
Murfreesboro, TN
Holy crap that is a PITA! Frustrating this was after all that work it really wasnt all that dirty. I didn't get any dog $hit that came out or anything. Weird. Hope I don't have a different problem!
Hummjay
Wild Thang
Seattle, WA
Thanks Drew for digging up this old thread!! I need this info as well but hadn't found it yet. Thanks 08H3 for the posting this, and thanks to everybody for the info!! After a fantastic summer with 80 straight days of sunshine and no rain (imagine that for Seattle!), our wonderful rain is here again so I'll def need to clean my drains. It was starting to leak thru the Onstar mic before summer but dried up. I'll try to tackle to this job this weekend...:sigh:
IndyHummers
Murfreesboro, TN
Same here, onstar mic on one side and the passenger side is essentially a waterfall. It would have been nicer if the drain plugs were longer and in a more accessible location but what are you gonna do. The passenger side is def. the worst. Good luck. I would recommend trying the air and pouring water down the drain to see if it worked. You should have puddles behind the front wheels. Make sure you pour enough that will be noticeable. If you don't have any water come out in a decent amount of time then you'll need to snake it or take the plugs out which are under the dash. Have fun!
By the way, if you read my original post, there's an update where I had to clean the rear drains as well. The method I described there DID work and with all four drains clear, we've had zero water problems.
Cortinas316
san antonio tx
Thanks for ur post....had the same thing happen to me today...after a many freak out sickstringc said to search the forums it's probably the drains....
Such great info intense forums. Thanks a ton. I'm gonna try air.and see what the result is.
I'll post the results.
WillieMo
Miami, FL
Just added this to my weekend duties!!! I have never checked them... don't think I have an issue but don't want to wait for one either...
Panzer07
Ontario, CA
It is an easy solution there's even a video on YouTube...this guy in Florida made...the only hard part is trying to find the rubber part that plugs to the hoses as well is a paint in the D trying to put it back in in you have big fat hands like I do...
