T nuts
Look up a structural steel product called "uni-strut". They have some hardware that is specifically designed for use on their strut systems. As luck would have it...I'm pretty sure they got a blind t-stud that will slide right into the gutter channel on the H3. Stainless of course.
mkmcgreg
Carmel
Stainless steel spring nuts also work great too.. That way you can use any bolt... May have to cut the spring off tho.. Most hardware stores should have them or an electrical supply house
S
SedonaBound
If you have a Woodcraft store nearby, they stock T-nuts.
