The less I drive it, the more maintenance I do?
Had a good round of work on the H3 today with Reloader's help. (Okay, "Reloader's help" means he does most of the hard stuff). I don't drive the H3 as much anymore but it seems it always needs something. Guess it needs some TLC at 143,000
  • Reprogrammed PCM installed (PCM of NC)
  • Left motor mount
  • Oil pressure switch - oil light was coming on at stoplights, would go away with increased RPMs (I paid $42 at O'Reilly for aftermarket, and it's only $16 on Amazon!!!)
  • Front brake pads
  • Transfer case fluid change - did it early, just to see color after about 2500 miles of use
  • PCV vent hose - this was soft and oil was seeping out and going down back of engine. Thought I had a different leak.
  • Oil change
  • Tire rotation
  • New nutserts in front crossmember for splash shield and skid plates
  • Tightened oddly loose lower control arm bolt
Next up - new upper/lower radiator hoses
When doing the brake jobs, AC Delco puts in that little packet of silicone in with the pads. I always want about 10% more than they supply, so I found the good stuff on Amazon. AC Delco Silicone Brake Lubricant - this is the good stuff for the pads, sliders, etc. and I don't think you'll usually find it in auto parts stores.
Highatop
Florissant, Co.
Sorry to hear about your problems. Some seems routine but, could your frontend problems be due to your new heavier bumper w/ winch? Havin the support and a place, Reloader's, to help is a real plus and is very good for you and your rig. Good luck.
Also, time to update your sig pic. Your rig has come along way and looks good
Could be. Wasn't bad work at all, just surprised at the list
Sent from my SM-N910V using Tapatalk
