jamesb1516
- Mckinney
Hoping this is common enough for someone to be able to give me some first hand knowledge. My 2008 Alpha has been making a rotating knocking noise. At first, I assumed it was from the crossmember bushing, so I replaced it with the Scorpworks piece. Noise is still there though, and it seems to have gotten more noticeable. Before it was intermittent but now its mostly always there when letting off the throttle or coasting steadily at lower speeds. I read a post on another forum that said if the crossmember bushing is blown out for too long, you'd develop a clunk when shifting from park to drive which meant that the prop shaft cv was bad. The transmission clunk is gone and the other noise is worse now. Dunno if its a cv axle or a bad prop shaft, but visually everything looks good. No ripped boots or anything. Any ideas guys?
